Select all warehouse products to move
Congratulations!
In the warehouse application, it is possible to move products from one warehouse to another.
For example, select a warehouse and use the pull-up of all products of the warehouse in all categories of screen 1
It pulls products to us, but does not indicate their quantity in the warehouse from which we pull. screen 2 and 3
Meanwhile, in the write-off there is an opportunity to add products in their quantity in the warehouse of screen 4
How can you add all warehouse products to the movement?
Why is there no such function in transfer as in write-off, it is logical that it should be.
Please add this feature.
Good day.
It is possible to implement the specified function for moving in the configuration mode and it will take 2 hours of finalization.
Issue an invoice?
26.09.2023, 08:54
Thanks for the answer. Good day!
28.09.2023, 15:47
No account required
28.09.2023, 15:48
