In the Warehouse application, add the ability to see the balances of the parent warehouse, taking into account the child ones.
Here is a link to the task for where the recommendation from the developers was indicated about this https://1b.app/ru/forum/warehouse-management/17418-dorabotka-sozdat-noviy-sklad-s-uchetom-roditelskogo-sklada/
Good afternoon. It will take about an hour to add a filter to one page, if there are several pages (for example 2, 3) then you can do it in the same hour if within the same task
Care Department OneBox production wrote: Good afternoon. It will take about an hour to add a filter to one page, if there are several pages (for example 2, 3) then you can do it in the same hour if within the same task
Good afternoon I can't understand what exactly you mean by "one page if there are several pages (for example 2, 3)"?
Care Department
Good afternoon
I just noticed in my work that I still need to see the same information in reports (here is an example of a report https://our-store.com.ua/app/report/designer/5/view/). You can also pay attention to this.
Care Department OneBox production wrote: Each page has its own filter by warehouses, so when you add a setting, it will not be added "to all places" but only to the places you specified.
Care Department
By pages do you mean tabs (https://prnt.sc/Vf_GtVmnnj0d)?
Yurchenko Roman Sergeevich wrote: I just noticed in my work that I still need to see the same information in reports (here is an example of a report https://our-store.com.ua/app/report/designer/5/view/). You can also pay attention to this.
Just paid the bill but noticed that you didn't answer this question. Tell me if this opportunity will be included in these works or not?
Good afternoon. The revision has been uploaded, the filter has been added to almost all tabs (in some it is not needed) and to the report https://our-store.com.ua/app/report/desiner/5/view/
Care Department OneBox production wrote: Good afternoon. The revision has been uploaded, the filter has been added to almost all tabs (in some it is not needed) and to the report https://our-store.com.ua/app/report/desiner/5/view/
Good afternoon Everything is working. Thank you!
Care Department
Good afternoon
