Possibilities and an example of the operation of the application "Warehouses"
Good afternoon, is there a video about the possibilities and an example of the operation of the "Warehouse" application?
Original question is available on version: ua 111
Igor, good day
Warehouses are a wide and voluminous functionality, taking into account the possibilities of automation.
You can check out the video https://www.youtube.com/@OneBoxOS/search?query=%D1%81%D0%BA%D0%BB%D0%B0%D0%B4
however, I recommend making the first settings with the help of integrators https://1b.app/ua/partner/search/?tags[]=3 , and after you get the basic settings for you, you can try to complete them yourself.
03.05.2023, 11:58
The problem is that on this YouTube channel there is a video about warehouses, but, as I understand it, it is from the old system.
As a result, it is not relevant now.
Do the first settings with the help of integrators? How to do it and how much will it cost?
03.05.2023, 12:43
111 Original comment available on version: ua
yes, the video is from the previous version, but the logic of the syllables is preserved.
To evaluate, we need a detailed technical statement from you, do you have it?
03.05.2023, 13:42
Detailed, unfortunately not
03.05.2023, 15:03
111 Original comment available on version: ru
For you, as a developer, the logic may be the same. But a lot of what they say in the video is actually not there, or to a friend
03.05.2023, 15:13
