Rate revision
Good afternoon
Please evaluate the revision:
1. The ability to set "Reserve before" for a product where there is a product passport, but it does not participate in warehouse operations
Product process example: https://arp.1b.app/3455/
2. In the action "Find the process upon arrival and change the business process and stage" add the ability to post materials for goods that have a passport - change the process and stage
To what extent is it possible to implement it?
Original question is available on version: ru Інтегратор CRM+ERP. Компания Olmonic
Morozova Olesya
Olmonic - FOP MOROZOVA O.P. wrote:
The ability to set "Reserve before" for a product that has a product passport, but it does not participate in warehouse operations
It makes sense to change this field only if this product is reserved. Those. do you need to change the process product field if the product is not involved in warehouse operations?
Morozova Olesya
In the action "Find the process upon receipt and change the business process and stage" add the ability to post materials for goods that have a passport - change the process and stage
I do not understand the connection between this action and the posting of materials. Do you want to somehow find processes in which there are products that you credited in this process and switch them? To do this, there is the action "Change the process stage when there is a sufficient quantity of products in the warehouse" and the checkbox "Run this process every 15 times" in it.
15.02.2023, 21:17
Olmonic Olmonic
Інтегратор OneBox
.dev
OneBox production wrote:
Morozova Olesya
Morozova Olesya
1. The process https://arp.1b.app/3455/ contains the product "Set of armor plates". This product is not credited, not written off
It consists of 2 goods - these 2 goods are credited and written off.
If these materials are in stock, how can I deliver the product in the order "Set of armor plates" Reserve To?
2. Does not switch if in the process the product is "Set of armor plates" which is not involved in warehouse operations, but only its components. Process https://arp.1b.app/3716/ . The action "Change the process step when there is a sufficient quantity of products in the warehouse" on the "test" procedure.
16.02.2023, 08:45
Інтегратор CRM+ERP. Компания Olmonic Original comment available on version: ru
Morozova Olesya
you can re-reserve them only by decomposing the main product into materials and reserving materials in the warehouse
Morozova Olesya
here the situation is the same, you have to decompose the goods into materials and wait until they arrive at the warehouse, then switch to the stage and make production
16.02.2023, 11:40
Olmonic Olmonic
Інтегратор OneBox
.dev
Morozova Olesya
Morozova Olesya
Unfortunately that doesn't work :(
And as far as possible to refine the action: "Change the stage of the process if there are enough products and MATERIALS in stock"
Is it actually real? ;)
06.03.2023, 10:59
Olmonic Olmonic
Інтегратор OneBox
The question is relevant
14.03.2023, 08:30
Olmonic Olmonic
Інтегратор OneBox
.dev
finalize the action: "Change the process step if there are enough products and MATERIALS in stock"
Please evaluate the improvement of the action: "Change the process step when there are sufficient products and MATERIALS in stock".
23.03.2023, 11:02
Good afternoon. If it is still relevant, then yes - you can make the setting in action, so that if the goods are not enough in the warehouse, they look for the opportunity to collect it according to the passport, and if there are enough materials, then transfer it to the stage. Takes about 5 hours to complete. Bill?
21.08.2023, 21:14
