[file]8092[/file]
1. Today we have been updated to the OS, but we cannot install applications on the system.
How to fix it?
2. How can I install all applications at once, so as not to play selectively?
1. Today we have been updated to the OS, but we cannot install applications on the system. How to fix it? 2. How can I install all applications at once, so as not to play selectively?
1. he should have been on the list already 2. no, everything is impossible and it's pointless to put yourself 300 applications and use 30 ... why do it? purely for the sake of creating a load on the system?
Kornev Mikhail wrote:
[file]8092[/file]
How to fix it?
can we add the option "choose multiple applications to install" so that we can select several checkboxes and install them at once?
arrived, thank you.
why is this?? well it's bullshit Do you bet a few every day? Or do dozens of applications come out a day that need to be installed? let's not waste each other's time on such ideas
arrived, thank you.
It is clear that I install applications once, but unlike others, I also think about how others will use it. I started yesterday to open applications, press the install button and wait. Moreover, later I forgot which ones I had already installed and tried to install some again, because at the bottom of the application it says: we recommend installing this, or be sure to install this. And I have been doing this for the second day, because the first time I installed them on a trial account ergo2. Let's spend time making any processes more convenient for users. Then I won't waste your time...
Ustimenko Igor
arrived, thank you.
same story here. if there was a multiple choice, then it would be possible to immediately turn on 10-20 applications, and not poke at each one.
[file]8110[/file]
same story here.
I'm not telling you, I'm suggesting. What other option do I have, besides asking about the problem on the forum? I'm asking or suggesting something based on problems I'm having that I don't think the user should be spending so much time on.
