1. Add the ability to search starting with two characters, or even one.
(example: google chrome address bar - you can already start the search with one letter)
http://prntscr.com/o93wwu - Onebox search only starts with 4 characters
2. Add the ability to expand the search with the symbol *
* - any characters/words will be before or after this character
3. Add the ability when searching - to create a new contact from the "contact directory" field, as well as from the "client" field.
http://prntscr.com/o93sin - add extra. field
http://prntscr.com/o93sqx - add it to the form
http://prntscr.com/o93sza - in the additional field "directory of contacts" you can not create a new contact
http://prntscr.com/o93t5p - in the field "client" - you can create a new contact
4. Make the left menu _completely_ hidden when you select the "hide" option. To appear on hover.
http://prntscr.com/o9409a
http://prntscr.com/o940xa
5. Add the ability to change the
1. Add the ability to search starting with two characters, or even one. (example: google chrome address bar - you can already start the search with one letter) http://prntscr.com/o93wwu - Onebox search only starts with 4 characters 2. Add the ability to expand the search with the symbol * * - any characters/words will be before or after this character 3. Add the ability when searching - to create a new contact from the "contact directory" field, as well as from the "client" field. http://prntscr.com/o93sin - add extra. field http://prntscr.com/o93sqx - add it to the form http://prntscr.com/o93sza - in the additional field "directory of contacts" you can not create a new contact http://prntscr.com/o93t5p - in the field "client" - you can create a new contact 4. Make the left menu _completely_ hidden when you select the "hide" option. To appear on hover. http://prntscr.com/o9409a http://prntscr.com/o940xa 5. Add the ability to change the
