Hello!
Regulatory authorities periodically change the requirements for writing abbreviated names of units of measurement of goods in documents.
After renaming the unit of measurement in the directory, it happens that this field for the product simply remains empty. And it needs to be reloaded. The ratio remains the same. There was a unit "rudder." [file]5464[/file] was then renamed to "roll". And now there is just a dash. We have a lot of such products.
Is it possible to make the name simply updated, and not disappear, because its identifier in the reference unit of measurement has not changed?
Hello! Regulatory authorities periodically change the requirements for writing abbreviated names of units of measurement of goods in documents. After renaming the unit of measurement in the directory, it happens that this field for the product simply remains empty. And it needs to be reloaded. The ratio remains the same. There was a unit "rudder." was then renamed to "roll". And now there is just a dash. We have a lot of such products. Is it possible to make the name simply updated, and not disappear, because its identifier in the reference unit of measurement has not changed?
Ustimenko Igor OneBox production Premium partner OneBox CTO wrote: the text name is stored in the product if you want to change it for products when renaming - revision 2 hours
Can investments be used for this?
Ustimenko Igor
Yes but you have to wait about a month then
Chausova Tamara wrote:
Ustimenko Igor
Yes
Ustimenko Igor OneBox production Premium partner OneBox CTO wrote: the text name is stored in the product if you want to change it for products when renaming - revision 2h
I'll wait. Only a big request, let me know when it's done!
Ustimenko Igor
Ustimenko Igor
Yes
