There is a created template https://box.ltec.com.ua/admin/shop/users/smsmailing/template/
If I try to select it in a bulk mail, I only get the first lines [file]4951[/file]
Is there a limit on the number of characters in templates?
How can I make sure that the whole text is pulled into the message?
If I just insert this text, then it sends everything.
There is a created template https://box.ltec.com.ua/admin/shop/users/smsmailing/template/ If I try to select it in a bulk mail, I only get the first lines Is there a limit on the number of characters in templates? How can I make sure that the whole text is pulled into the message? If I just insert this text, then it sends everything.
Restrictions are not for templates, but for the SMS itself. If my memory serves me right, then an SMS with a text completely from Latin in one SMS fits 140 characters (including spaces), and if there is at least one Cyrillic character in the text - 70 characters including spaces. If the text is longer, then there is a breakdown into several SMS. It is possible that in your case the rest of the text will come later, after all recipients have received the first part.
hello, in this case the text was cut off after a special character (quotation mark), we took your question into consideration, I will let you know about the decision
Zamogilny Dmitry wrote: hello, in this case the text was cut off after a special character (quotation mark), we took your question into consideration, I will let you know about the decision
Thank you! expect
Thank you! expect
