Block for importing products into the application
"Import stopped working in Vendor Order transactions
Today out of 20 attempts, it worked 2 times.
I click Download and nothing happens. I tried a bunch of options with the number of columns and file type, etc. etc. Nothing helps. Everything worked great before."
https://orc-test.kiev.ua
Problem for other clients:
https://crm-onebox.com/ru/support/stock/7741-blok-importa-produktov-perestal-rab...
Good afternoon, please give a link to the process and a file that can be downloaded
19.03.2021, 15:30
Good afternoon. Please do not create additional topics so as not to discuss the same thing in parallel in two tasks https://crm-onebox.com/ru/support/other/7764-blok-importu-produktiv-v-zamovlenny... .
19.03.2021, 15:32
Good afternoon. Fixed the problem
22.03.2021, 11:52
