Printing barcodes/price tags
https://mariemur.crm-onebox.com/
Price tag template https://mariemur.crm-onebox.com/admin/shop/pricecode/templates/1/control/
Example https://mariemur.crm-onebox.com/admin/pricecode/13539/control/
We started printing price tags, we need to print not horizontally, but vertically. The label size is https://prnt.sc/zl4trn
I didn't find how to do it, please help me.
If this is not possible, is it possible to somehow download all the barcodes? we will try to do it through another program
Opportunities to do this by layout - no.
Do you need existing price tags to get? Or generate and receive?
And in what form - the layout of your template or a direct link to the product barcode image?
16.02.2021, 17:17
Is there an example of how the current price tag template prints on this printer?
Horizontally or vertically, but not the entire size of the printer? Perhaps all the same, positioning in the template can achieve some result
17.02.2021, 09:13
We recorded a video + photo of how it happens, so it will be clearer
17.02.2021, 12:27
I'll take a break to think about how you can make a vertical image of a barcode.
17.02.2021, 17:45
In general, I can programmatically rotate the image for you by 90 *
As an example - https://mariemur.crm-onebox.com/media/productbarcode/product27929external_rotate...
Try this image through "Source" in the document editor, paste the price tag and try printing.
If it suits you (that you will only have to adjust the layout styles of the template to fit the print size) - then I can make a variable {barcodeimageexternal_rotate90} that will make a rotated barcode image
18.02.2021, 17:44
