Justin Bugs
This is possible when Justin in the issuance of branches indicated the maximum allowable weight = 0 kg.
In this regard, the basic checks of the allowable weight for the department worked.
We added more checks to check the maximum allowable weight only if it is specifically passed from the API greater than 0.
04.02.2021, 17:15
How to set up correctly so that ttn is generated 0 set?
Administrator wrote:
but when Justin in the issuance of branches indicated the maximum allowable weight = 0 kg.
04.02.2021, 18:00
now and so it should be generated
04.02.2021, 18:06
