Problems in the speed of the CRM. CRM is malfunctioning.
When you try to load a page within our CPM, the download occurs on the second or third attempt. It takes a very long time to load. Impossible to work! The company has become!!!!!
Find out what the problem is right away!
Problems in the speed of the CRM. CRM is malfunctioning. When you try to load a page within our CPM, the download occurs on the second or third attempt. It takes a very long time to load. Impossible to work! The company has become!!!!! Find out what the problem is right away!
Good afternoon. There are no problems with the operation of the server on which your system is located. The server is available, the pages are opening. The error you showed in the screenshot says that your browser cannot find and connect to the server. This may be due to network problems, either your local network or problems with your ISP.
Where are the web site servers that you use in your work, I do not know. Physically, the server of the CRM system is located in the DC, which is located in Germany. Perhaps the provider that provides you with Internet services has problems specifically in this direction ... What is actually happening, I do not know, I can only assume based on that information. which you provided (screenshot and type of error). Before answering you, for about 15 minutes I went through the pages in your system, no problems were noticed. Your server has also been checked. All services are working normally, no errors or failures have been identified.
