AZ filtering works weird
The specified "buttons" in the table header filter any content as strings and not as numbers
28.01.2021, 18:34
Bodyako Dmitry
I got it right:
https://prnt.sc/xrrxbj - brought out another process where the name is in transliters. It was brought up by the filter since A-Z takes into account English. font. That is, filtering is by name.
Is it possible to make it work like numbers?
28.01.2021, 21:17
yes, but it needs to be done from the back end
29.01.2021, 16:34
Bodyako Dmitry
Ok, how many hours does it cost to modify if it is like the same setting - https://prnt.sc/xsogqb ?
01.02.2021, 17:41
Timofeev Artem Olegovich
The same setting can be made here - it is impossible, because objects are sorted there, and here the data is considered in arrays.
Unless you do something similar - like clicking in the header, the ASC / DESC sorting will also change - and on the counting side, then convert the values \u200b\u200bto numbers (without spaces and other things), re-sort the main entity (using your report as an example - this is a media plan) and the output will change accordingly - but I don't think it will take less than 6-7 hours for 1 template (which has such sorting).
02.02.2021, 11:33
