System settings not working
Good afternoon. There was some kind of malfunction in the Van box, documents are not being pulled up, I wanted to check the settings: I go to "system settings", select "other", a blank page opens - there is not a single item from the settings.
Your server has run out of space.
As free - we can remove the caches of empty pages and everything will be available.
04.01.2021, 14:26
Contact the host with a question:
- to increase your disk quota;
- crowns have not been working for you since 2020-03-30.
04.01.2021, 16:00
On the server freed up space, now everything works.
And what does it mean "crowns do not work" what is it?
04.01.2021, 16:13
Berezinets Andrey
This means that automatic actions do not work for you.
Everything worked until 2020-03-30, then, as far as I remember, Hwasting had a problem with the server and
clients were transferred to another server, but apparently not everything was configured.
04.01.2021, 16:19
