Action when saving a contact card "Fill in a product card based on passport materials"
Installed action without settings https://prnt.sc/vt5tm0 .
Here is the passport http://saleswp0.crm-onebox.com/admin/shop/storage/passport/4/edit/
1. With the current settings of the action, if I save any component, then the prices of the produced product change. Although they shouldn't.
Should only change if you set this setting https://prnt.sc/vt5utp .
2. How does the setting "Use in action only passports where the current product is the manufactured product" work? For this checkbox to work, you need to select a passport in the product card?
3. "Run automation on save for produced products" - how does this setting work? In fact, it turns out the same as this one https://prnt.sc/vt5wq9 .
1. Judging by the technical specifications - they should
2. No, this is done in order to trigger the processing of an action only for those products in which the processed product is not a material.
3. You keep the product, which is recorded in the passport as a material. If you enable this checkbox, then after saving it, automation actions will be launched for products that are produced in the same passport.
01.12.2020, 09:59
Something is not right here. Then it turns out that there is no difference between 1 and 3 points. Because without turning on the settings in step 3, and so automation starts for all passport products.
Here was a consultation #2015658621 , which indicated that in order for information about a manufactured product to be updated while saving a component, you need to enable the settings "Use only passports in action where the current product is a manufactured product" or "Start automation when saving passports for all products where the product participates "
I even have a video showing that if the settings are turned off, then when the component is saved, the manufactured product is not updated.
That is, if I enable this setting, according to the passport http://saleswp0.crm-onebox.com/admin/shop/storage/passport/4/edit/ and save some material, then only the manufactured product will be updated, and its no ingredients?
Now it works without setting a checkmark.
01.12.2020, 10:27
Dima, give me an answer, please.
02.12.2020, 12:38
1. The manufactured item is updated when the components are updated. This is how it should work, it's not a bug.
2. This is not written there, it only says that only passports where this product is manufactured will be processed. Why are you adding materials here?
03.12.2020, 17:29
Bodyako Dmitry
I was answered here #2015658621 that in order for the manufactured goods to be updated when updating components, you need to set the checkboxes in action. And then it didn’t work, I even had a video left on which you can see that without the checkboxes checked in action, it doesn’t work.
Bodyako Dmitry
Can you show how this works using the example of this passport http://saleswp0.crm-onebox.com/admin/shop/storage/passport/4/edit/?
03.12.2020, 17:53
