launch a revision on the use of variables in links added through the global menu
please put the following task into operation (estimate 2 hours, here is a link to the estimate / )
- improve the functionality of using variables in links added through the global menu, namely
make it possible to specify the [cdatetime|date_format] variable in the added link, for example:
https://oneboxconsulting.com.ua/dashboard/?filterdatetofrom=[cdatetime|date_form...
and so that when clicking on such a link in the global menu, [cdatetime|date_format] is replaced with the current date in the format specified in the date_format variable i.e. just like it works in the "Fill process or contact field" action.
the result should be a link
https://oneboxconsulting.com.ua/dashboard/?filterdatetofrom=2020-11-18+00%3A00
This improvement will make the box even more flexible and will allow you to generate links to lists of processes that
- scheduled for today
- created today
- must be completed today
- etc.
