The filter in products by additional field does not work correctly if you specify 0 in the value
Тут https://baza.cn.ua/admin/shop/products/?filtercustomkodkategoriirozetka23=&f... &fromfiltercustomzalishok25=0&tofiltercustomzalishok25=0&filtercdatefrom=&filtercdateto=&filtertags=&filtermodel=&filtershare=&categoryid=1594&searchLine=
I filter by these parameters http://prntscr.com/u1mmaa
That is, I have a field "Overage" and I filter the values where in this field "0" http://prntscr.com/u1mn1o
If I filter the value 1, 2, 3 etc. then everything works fine, but if you set it to 0 it doesn't work
Good afternoon, Vlad Valerievich.
The filter is working correctly.
https://prnt.sc/u1nrgx
In the field from and to you need to set values from 1
And in order to filter 0, you need to check the box as in the screenshot (Out of stock)
https://prnt.sc/u1nrt8
and click filter.
And get the desired result
https://prnt.sc/u1ns49
18.08.2020, 17:06
Куприян Владислав Валерьевич
And where does "out of stock" I filter by an additional field that has a numeric type, 0 is also a number, I write values \u200b\u200bin this field, why can't I filter by 0 ?
18.08.2020, 17:25
0 is also a number in mathematics, and programmatically 0 is perceived as - or not available.
Therefore, 0 cannot be filtered. And that is why it is issued separately - Out of stock.
19.08.2020, 09:06
Somehow I do not understand the logic of the functional
Look, I created an additional product field, the type is numeric
I write in it any numbers from 0 to 999999
The fact that I connected all this with the presence, let's not consider this task at all, since I just came up with such a crutch, since there is no filter in the system by the amount of residue in the products
So I created a field in which I write values and it comes out according to your logic, I can’t filter products by this field in which I wrote 0 in this field (that is, it was 1, then I wrote 0 there)
What is the logic here that I cannot filter products
20.08.2020, 18:49
You can filter by a numerical value from 1 to 999999 or by the absence of this value if you have 0 set. Since 0 is programmatically perceived as the absence of a value.
21.08.2020, 10:15
That is, if you entered in the field from and to 0 and clicked filter, it is programmatically perceived in the same way as if nothing is entered in these fields and you clicked filter, the result is the same.
http://i.imgur.com/0AIHc0e.png
21.08.2020, 10:23
Why are you explaining to me how it works now, I understand it perfectly
I don’t understand the logic why it works this way, in any systems you can filter a numeric value by any data, even though it’s 0, even though it’s 999999, why does it turn out that the system cannot filter by 0, can you modify it somehow?
21.08.2020, 10:40
Kupriyan Vlad Valerievich wrote:
I don't understand the logic why it works like this
Because that's how the php programming language works
in any systems, you can filter a numeric value by any data, even though it is 0, even though it is 999999, why do you get that the system cannot filter by 0
you can sort from 0 to any value, from largest to smallest, or vice versa, if you make this field sortable
21.08.2020, 11:03
Does that mean you can't do it?
Is it possible to sort additional product fields?
21.08.2020, 11:36
I told you that the filter works correctly, if you need to sort additional fields or if you have any other wishes for the box functionality, then these are improvements.
21.08.2020, 11:51
1. You said that you can sort, how to do it, if not, how much will the revision cost?
2. You can modify that it would be possible to specify from 0 to 0 in the filter and the system showed all records in which in this additional field 0, if so, how much will it cost?
21.08.2020, 12:14
Vladislav, I understand the essence of your appeal, but please specify why to filter from zero to zero https://prnt.sc/u1mmaa if there is a special checkbox "out of stock" https://prnt.sc/u52l7a ? If you need to filter from zero to a certain number, then you can enter zero and the number you need, and the filter will work correctly (example from zero to three): https://prnt.sc/u52mls plus, if other fields are taken into account https://prnt.sc/u52o91 growth, I think, in principle, cannot take on the value 0, you also do not see goods with a price of 0.
24.08.2020, 19:47
The filter in products by additional field does not work correctly if you specify 0 in the value. I told you that the filter works correctly, if you need to sort additional fields or if you have any other wishes for the box functionality, then these are improvements.
You said that you can sort, now you say that this is a refinement, how much will it cost?
24.08.2020, 21:29
02.09.2020, 23:47
