Flew completion on sending automessages
Hello, once again there was a failure in finalization, section 2 automatic actions once an hour", here is a screen from one of those tasks that I created as bugs earlier https://prnt.sc/oldfot (in order for you to understand that this task is was and sometimes worked) )
now : http://joxi.ru/YmEgvqDSMMOMJA
Hello. The actions are in order, they were not displayed for setting but were. The problem has been fixed, now they are visible in automatic actions once an hour with the same settings as before
30.10.2020, 09:44
Maria, they were not displayed or sent. Those. the action did not work, we will check that now. Thanks
30.10.2020, 11:17
STOP ! http://joxi.ru/823WVgpu88Req2 this action sends only to mail. We had a revision, and the action was sent wherever possible, including instant messengers and instagram direct
30.10.2020, 11:20
Netudykhata Inna
you have 2 such actions: the first sends as you indicated to Email, and the second to messengers http://joxi.ru/v29L8JjuZn19Gm
30.10.2020, 11:22
Hello
why is this action not working again? client:https://crm.mama.travel/admin/shop/users/54361/
25.11.2020, 16:00
