Communication through a special office
The manager sends a comment to the client from the appointment - the client instantly takes it in the office.
If the client sends a comment from the office - the manager needs to change the side to make this comment.
VanBox can't give the manager a signal that the client has written to you?
Schos bude blimati, for example?
Good afternoon!
When the client writes a comment in the order through the personal account, the manager will receive a notification on this order in the communications center.
28.10.2020, 12:06
Гуляєв Олександр
Друкарня "Друкарик"
Zrozumov, dyakuyu.
Can't connect the communication center and the redacting office?
Tobto on the side of editing http://prntscr.com/v8jx9i request to add the communication center http://prntscr.com/v8k1y2
More such a thing http://prntscr.com/v8k2ub
The center of communications with a choice of requests,
ale, if you choose otherwise, the center of communication is lost.
28.10.2020, 12:34
If you are in the communications center and clicked on an order, then the communications center will remain open on the left side, and on the right side you will work with the order.
Also, the notification counter is always displayed here https://i.imgur.com/RaHCdOK.png and you can see if a new notification has arrived.
28.10.2020, 13:05
integrator
integrator.com.ua
Gulyaev Oleksandr Drukarnya "Drukarik" wrote:
Zrozumov, dyakuyu.
in the center of communications, all changes are spent on all processes, devi are known.
If the client has signed a comment in the zamovlennya, de vi є the author / vodpovidalny / posterigach through the office, then you will come to the communication center of notification.
28.10.2020, 17:50
