the clock crown does not work
Good day. The server has been unstable lately. Screenshot: https://prnt.sc/siSbQJntXCqB
"gaps" in time coincide with the work of this clock automatic action: https://prnt.sc/-qTL0N4ja60O and are most likely related to it. Although there were no global changes and the problem was not observed before.
maybe something needs to be fixed on the server?
boxing: https://crm.sportmarket.ua/
The cron operates on schedule.
On the graph, the "dips" show that the hourly cron has been running for longer than 1 hour since the previous launch.
The script is launched at the N-th minute of every hour, so if the previously launched script has not finished its work before the next one is launched, and the graph is also built by this script, then we see a "gap" on the graph.
25.11.2024, 11:04
Потяко Дмитро Олександрович
that is, the cron works to the end and performs its function? or it does not perform the action to the end?
25.11.2024, 11:15
Potyako Dmitro Oleksandrovich wrote:
that is, the cron finishes working to the end and fulfills its function?
Yes, the crown is being improved.
When "gaps" are visible, the crown works for more than an hour.
25.11.2024, 12:19
