Good afternoon
Yesterday's problem is repeating itself again
no new actions were added
screenshot taken at 11:09 today https://prnt.sc/yDMwhAmevpyq
https://kiyservice.1b.app/app/system-statistic/
What could be putting such a load on the system?
I turned off all actions in actions once an hour and still these numbers are now https://prnt.sc/uAcOP8MjjDmz can you tell what exactly loads the system like that?
requests in apiv2. Find out who makes them and why and change the logic. 1. For each request, an API token is obtained AGAIN (although you can use the one you have already received and receive a new one only when the first one has expired) 2. Getting a list of orders for each status with a limit of 200. That is, you are laying the system for yourself.
let him cook OneBox production wrote: requests in apiv2. Find out who is doing them and why and change the logic. 1. Apitoken is received AGAIN for each request (although you can use the already received one and receive a new one only when the first one has expired) 2. Getting a list of orders for each status with a limit of 200. That is, you build the system yourself
let him cook
didn't help
the script was turned off
now the indicators are https://prnt.sc/SkY_C79DuwgU and they are growing
Requesting a list of orders for each manager and status separately once a minute is certainly too much, a good idea. Are you displaying some kind of dashboard there or what? Why spam so much, and with such strange requests. Why not send an array of statuses or managers. Or filtering by creation date or something else?
let him cook OneBox production wrote: [2024-09-11 14:19:47] host: kiyservice.1b.app URL: /api/v2/token/get/ contentID: api-v2-get-api-token point: /shop.starter.php engine_sessionid: 1726053587_1059 IP address: 176.9.57.117 didn't turn it off
let him cook
didn't turn it off
turned off both scripts that could load the CRM
now the indicators are like this https://prnt.sc/EwEHctdFcVB3
[2024-09-11 15:12:08] host: kiyservice.1b.app url: /api/v2/token/get/ contentID: api-v2-get-api-token point: /shop.starter.php engine_sessionid: 1726056728_1234 ip: 176.9.57.117 More than an hour ago, it was like 14:30 or earlier, but API requests from this IP are still going. The switch doesn't turn it off somehow
ip: 176.9.57.117
now the indicators are like this https://prnt.sc/yG-aQwdS4XCX the switch worked) last request was [2024-09-11 15:12:48] what other reasons could there be?
the switch worked)
You need to analyze the load, see what requests are coming and from where exactly. It will take from 3 hours to ten +-. If you agree to pay for the hours spent, I will look at what exactly is causing the load on this project and give recommendations for correction.
Good afternoon
The clock crown is frozen
can you restore its work?
turned off all actions on the watch crown, still didn't help(
