Since yesterday, process pages have been loading slowly. Some kind of glitch in the telegram + integration settings, the processGeoCoder process appeared in a minute crown
The processGeoCoder process appeared in a minute, and if it existed, it began to take the longest to work. What is it connected to, Google? Integration was disabled, but nothing changed.
In the integration settings, telegram writes “The token is not valid. Check if it is correct,” but the tokens are valid.
An error occurs periodically in the console when loading pages.
A process with a couple of blocks in the interface loads in about 16 seconds
too much in one topic
Which of this is relevant?
03.12.2023, 17:54
Here the problem has already been solved through TP, thank you. The hoster's DNS has changed.
03.12.2023, 20:33
