Good afternoon
I need to change my SSL certificate expires in 10 days, the seller said I can’t just renew it, it will be like buying a new one. Those. it needs to be installed
Can I send the invoice and to whom? How long will it take (when does it need to be sent in order to change it in time?
Good afternoon I need to change my SSL certificate expires in 10 days, the seller said I can’t just renew it, it will be like buying a new one. Those. it needs to be installed Can I send the invoice and to whom? How long will it take (when does it need to be sent in order to change it in time?
Nikita Nikolaevich Bidenko wrote: How long will it take (when does it need to be sent in order to change it in time?
The installation can be done as soon as you have a new certificate. We can set - 1 hour.
