Clear box https://crm.kupistul.ua/
Good afternoon
Tell me, is it possible to clear the https://crm.kupistul.ua/admin/shop/statistic/ box from technical files? If yes, what will be the cost?
A few days ago, additional photos were removed from all product cards, only the main photo was left (cleared through importing products from xls , added a checkbox to clear additional photos on upload), the Delete unused images action was added, but no changes are visible in the Load Control Panel.
Can you tell me how else you can clear disk space?
you have nothing to clean
I think it's better for you to go to the hosting panel and increase the tariff for the one where the disk is larger
26.07.2023, 16:18
And you can clarify. We have 2 discs. If one fills up, does the second one automatically start filling up?
28.07.2023, 09:37
there is no such logic
28.07.2023, 10:48
