It worked, thanks! Tell me, what is the reason for the stop? Is it possible to make a notification in the system that the cron has stopped? This is very critical, and you do not immediately see the problem. I'm sure this will be a much needed feature for everyone.
Why did the minute crown stop? In the description of the ticket, a screen from the last date of processing.
Now it's working and orders from Opencart came 2 times
[file]19948[/file]
[file]19948[/file]
Why did the minute kroner stop? In the description of the ticket, there is a screen from the last processing date.
Now I have earned money and orders from Openkart have come 2 times
most likely, you will need to pay for the time spent investigating your issue - because it takes time, and you have a box
[file]19948[/file]
Farkhshatov Rodion wrote:
[file]19948[/file]
[file]19948[/file]
[file]19948[/file]
[file]19948[/file]
[file]19948[/file]
Farkhshatov Rodion wrote: Can you consider implementing the cron stop notification feature in future notifications?
You can create a topic in which to describe this functionality and the developers, together with the company's management, will consider the feasibility of this improvement
