You need to clean up disk space (logs, histories), maybe you need to compress the logs, those that are older than 20 days will be deleted. Perhaps you can configure some more auto-delete
Good afternoon. You can change the number of database backups up to 5 (for the last 5 days). Clear logs and configure system log compression. All this will add ~7 GB. - 1 time.
- 1 time.
Ok, let's reduce the number of backups, set up log compression, and ask you to delete old mp3 conversation recordings I deleted a part myself, but a part remains, does not want to delete, and there is 6 GB
You can make an account
[file]18329[/file]
[file]18330[/file]
Good afternoon. Storage of database backups reduced to 5 (for the last 5 days). System logs are compressed, those older than 15 days will be deleted. Available disk space - 18G
Tashuta Sergey Grigorievich wrote: we will reduce the number of backups, set up log compression, and ask you to delete old mp3 recordings of conversations
To remove old files from the box there is an action: "Automatic actions once a day" finds an action "Clear data on old events" Fill in the field, how old we want to delete: "Events created more than: 1095 days ago" (3 years ago from today) Selects the event type: "Event type:" - "calls"
