Financial format of numbers at the special office
For example, the axis is here https://univer.1b.app/admin/shop/boxclient/2/interface/?groupid=5
for the field types "number with floating point" in the "Universal client block" and "Universal block" blocks, to set the "adjust data in the financial format" - all numbers with a digit in thousands, positive values in green, indicative chervonim with the sign "-" , rounded up to tenths at a time: 1000000, guilty buti - 1 000 000.00
For example, add either for the upper block, or opposite the skin field (Fig. 1).
How many years are required for the implementation of two options?
Is it only for additional fields or is there a list of standard fields that are also needed?
25.07.2022, 23:09
Пятецкий Николай Николаевич
Insiders - OneBox
Da Hong Pao
Well, I don't remember standard fields where there are only floating point numbers. But this option could also be considered. probably you should just put a condition, if the field is a number or a floating point number, then give the opportunity to check the box "Output financial format of numbers."
27.07.2022, 13:46
Insiders - OneBox
da hong pao tell me, is there an estimate?
01.08.2022, 15:55
We can file the setting in the block for additional fields. Takes 2h.
03.08.2022, 21:34
did like this, settings
11.08.2022, 10:36
