Improvements for a personal account - 2 :)
1. It is necessary to supplement an existing one or make a new block where one could add a button (ideally one block and one button in it) so that several such blocks can be displayed. The logic is simple, we click on the button, a process is created that we specified in the settings and the client immediately gets there on the created process. The style of the button is the same as for all buttons in LX (blue).
2. Here (Fig. 1) https://univer.1b.app/admin/shop/boxclient/10/interface/?workflowid=14&statu... you need to add a block where you could to choose which process to create with this product. (Fig. 2) - in this table on the right, so that it would be possible to display the button (in the settings you can set its name), these buttons will be on all products of the process and when you click on one of them, a process should be created which we specify in the settings and copy the product there with all the fields and extra
1. Empty order?
2. Is this an order products table? In it, opposite each product, there should be a button to create a new order and add the same product to it?
12.07.2022, 15:25
Пятецкий Николай Николаевич
Insiders - OneBox
anonymous hamster
OneBox production wrote:
1. Empty order?
In fact, yes. Only for each button we can assign which bp to create.
anonymous hamster
Yes. This is necessary for any interaction with the product. Type to copy and immediately create a process, so that there are already all sorts of manipulations to do. Just copy, don't move
12.07.2022, 17:35
1. Okay. We can make 10 blocks identical where there will be only 1 button, in the block settings you can set the bp block in which to create, the name of the block, if necessary, and the name of the button. The order will be empty, the client of the order will be the one who pokes at it. Didn't forget anything? You can do it in 3 hours.
2. How do you want to set which product to create which bp? There may be tens of thousands of goods in boxing. Or will you only have a few and will there be a choice of goods-bp right in the block?
12.07.2022, 20:24
Insiders - OneBox
anonymous hamster
Accepted. Looks like I didn't forget anything. I'll post confirmation a little later.
anonymous hamster
That it will be tough) Just in the settings of the product list block, display a drop-down list like "Select which business process to create when you click on the button" and, accordingly, the field "Name of the instant process creation button" would be below and just this whole story or bang right away by default, or that there would be a choice of such an item and you could choose its position in the table yourself.
12.07.2022, 21:05
aa, for all goods the same bp should be set? Then it's not a problem, also 3 hours and everything will be fine. In the block settings there will be a separate process product field like "Order creation button", in the block there will be a setting for how to name the button and which bp to create. When you click, an order will be created, the goods will be copied to the order (price, additional fields, fields, if you need something else - write). After creating the user, he will throw on a new order. Looks like I didn't forget anything.
13.07.2022, 09:40
1. Block "Create process", you can add 10 blocks. Should be enough. Settings inside.
2. In the table of products such settings. If BP is not selected, the button is not displayed.
17.07.2022, 23:28
Insiders - OneBox
anonymous hamster
We look at the client block (Fig. 1) https://univer.1b.app/app/contact/17/
We go to the personal account under his name, click "change details" (Fig. 2) and not what is needed is created at all (Fig. 3)
And in the card you can see that extraneous processes have been created (Fig. 4)
anonymous hamster plz fix the bug.
21.07.2022, 18:03
I can’t find where the button is displayed - it’s not in the profile
26.07.2022, 20:09
Insiders - OneBox
Da Hong Pao
https://univer.1b.app/admin/shop/boxclient/2/interface/?groupid=5
27.07.2022, 18:35
Insiders - OneBox
Da Hong Pao
da hong pao can you please fix the bug?
04.08.2022, 12:46
Sori, I only tested adding when 1 block. When several blocks, unfortunately, they worked all in turn. Corrected.
12.08.2022, 12:27
