Do not work automatically
Good afternoon. Three weeks ago, such a problem was already boulevard, and again they do not work on automatic devices.
For example, "PromUA / Export products in XLS format" - here the file for uploading is not automatically created, manually - every other time. Dia - "Put a business process for the purchase of products for an employee" also does not create processes automatically, manually every other time.
There was also a problem with mass data change in products through the mass data change panel. For example, it is necessary to set for 800 goods the date of the reduction, we see all 800 the date is taken, we choose and nothing is given. And if so, pay less number of goods, for example 50, then change the data.
Here is a topic from the top: https://1b.app/ru/forum/other/13816-ne-pratsyuyut-avtomatichni-dii/.
Reason: Automation stopped working because when updating the system, the server had problems with resources and the Linux kernel "killed" and rest
The source is the same as last time.
Automation stopped working because When updating the system, the server encountered problems with resources:
Jun 16 01:02:25 bigcatch kernel: Free swap = 0kB
Jun 16 01:02:25 bigcatch kernel: Total swap = 524284kB
Jun 16 01:02:25 bigcatch kernel: 1048479 pages RAM
Jun 16 01:02:25 bigcatch kernel: Out of memory: Kill process 25457 (mysqld) score 590 or sacrifice child
Jun 16 01:02:25 bigcatch kernel: Killed process 25457 (mysqld), UID 994, total-vm:5005716kB, anon-rss:2409764kB, file-rss:0kB, shmem-rss:0kB
Jun 16 01:02:25 bigcatch systemd: mariadb.service: main process exited, code=killed, status=9/KILL
Jun 16 01:02:25 bigcatch systemd: Unit mariadb.service entered failed state.
Jun 16 01:02:25 bigcatch systemd: mariadb.service failed.
Now the automations are working.
17.06.2022, 13:00
I so razumіyu tse problem і from memory. Tell me, be kind, we have a vps tariff for 4gb, changing the tariff for 6gb will help to prevent the repetition of this situation?
17.06.2022, 13:08
Yes, these are memory problems, but I don’t know why memory leaks occur.
Perhaps increasing the swap memory will solve this.
we have a vps tariff for 4gb, change the tariff for 6gb
Not sure if this will help.
17.06.2022, 14:23
