Here is a setting
[file]15023[/file]
need the same but to write the value to the article
How many hours is this?
And do I understand correctly that later, when importing, it will also search correctly?
That is, for example, in the file code = "123" we make the preposition "test"
in crm it will be test123, but in file 123 and the system will understand this and update the products?
Here is a setting
need the same but to write the value to the article How many hours is this? And do I understand correctly that later, when importing, it will also search correctly? That is, for example, in the file code = "123" we make the preposition "test" in crm it will be test123, but in file 123 and the system will understand this and update the products?
