Selecting all items does not select all items
Hello, when we go to the list of products and, for example, select a filter - in stock, without a category, a specific supplier, in the search on the right we write, for example, "keyboard", we find more than 50 of them .... in order to select them all and send per category, either 50 pieces are allocated, not all the required positions. Or positions remain, there are 20 pieces, then we select them, and 10 remain, then 2. In general, not all positions are allocated.
You can use multiple options
1. Increase the amount of information displayed in the table
http://joxi.ru/V2VONOyCKbgLYA
http://i.imgur.com/LvT3MVL.png
2. When selecting, use
http://i.imgur.com/DhVUkSu.png
Thus, it selects all filtered positions, the only difference is that when you select more than 50 items (select all, as in the screenshot), the System does not act immediately, but after starting the minute handler. That is, if you perform an action with more than 50 positions, then wait 1-3 minutes, the action should be completed.
21.09.2020, 10:48
1.2. And so they did.
But in the end, all the same, positions remain not all but less, even if there are 12 of them ... 4-6 remain ... then again we do the same. Not always, but such bugs are observed.
21.09.2020, 12:36
