Evaluate the refinement of adding a cell to an action send a Telegram message
Box https://tashuta.ua
Need to add cell as is in "send message to Viber" action
into action "send message to Telegram"
The cell is called "Submit file from additional process field"
OK, put it up. check. Igor, please read the message and also rate this thread https://1b.app/ru/forum/online-stores/11971-otsenka-dobavit-ikonki-v-harakterist...
26.04.2022, 20:40
Good afternoon. Refinement completed.
29.04.2022, 15:33
Maxim, good afternoon! Everything works, but only if you attach the file yourself in an additional field. But if you use the "Write document" action and add a file to an additional field, the file will not be sent to telegrams. Sending to viber on the same principle works fine.
The events will show that the file is gone, but in fact it does not come
Again, I repeat that the viber file comes
13.05.2022, 13:26
Please indicate the link to the problematic process - I will check if the file is written there correctly, etc.
24.05.2022, 15:37
