The additional field calculated by the formula with the number "0" is not displayed in the automation "Integration of XML products (Export)"
In the "Integration of XML Products (Export)" automations, we display an additional field, we calculate it according to the formula "1-1", as a result, zero should be displayed. But instead, in the resulting xml file, there is an empty line:
This is what the extra looks like. field in atomization:
So we consider this field according to the formula:
Link to xml:
https://portal.flytechnology.ua/media/export/product/flytech.xml
OneBox Corp - Інтегратор
Link to xml:
If the field is of type "Integer number", then 0 is not a value, but emptiness. With the current settings, you can change the field type to a string and write 0 + check the box in the formula
04.01.2022, 13:34
Sukhanitsky Andrey
If the field is of type "Integer number", then 0 is not a value, but emptiness. With the current settings, you can change the field type to a string and write 0 + tick in the formula
Done, didn't help
04.01.2022, 16:15
Do you have a default value there or from an additional field? Remove 0 from the default column. Is there a value in the field?
05.01.2022, 21:29
Sukhanitsky Andrey
OneBox Corp.
By default, zero stood, removed. Still the presence tag is empty in xml
06.01.2022, 16:42
Is the field filled in the product card? Check what I wrote above.
Show with screenshots the field type and value in the product card
07.01.2022, 10:37
Here are screenshots with the field type and value in the card
10.01.2022, 12:11
The xml still renders incorrectly
10.01.2022, 12:12
Have you already dealt with the problem? Or accidentally closed the ticket?
10.01.2022, 15:39
by chance) the problem is not solved yet
10.01.2022, 17:07
I checked everything I could, at the moment there is only one solution (see screenshot)
Or modify so that the file understands 0 as a value
16.01.2022, 03:22
