In automation, once a day, you should:
[file]12847[/file]
Prote, what are the processes going on. For example:
https://zhiraf.crm-onebox.com/admin/customorder/issue/23838/edit/
https://zhiraf.crm-onebox.com/admin/customorder/issue/23817/edit/
Good afternoon, for those who have more than 1 record in the database for rich contacts with this additional field, that will be inconsistency of minds. What rank did you fill in the doppole (ObovyazkiUAH)?
Do you tweak the /api/1c8x/contact-set/ method? I just don’t download yoga in the logs https://zhiraf.crm-onebox.com/admin/shop/report/logs/ by the set-contact key for the next hour
Having reviewed the nutritional status, from the rest of the applications,
https://zhiraf.crm-onebox.com/admin/shop/users/82645/history/?authorid=&systemchange=1&filter2_key=valueold&filter2_type=search&filter2_value=&filter3_key=valuenew&filter3_type=search&filter3_value=&fieldkey=&filtercdatefrom=&filtercdateto=
here you can see that the data is restored in a second, what rank have you done to automate data updates?
Vivantage with 1 with a request &userid=11007&customfield_ObovyazkiUAH=0&customfield_DolzhnimiUAH=0&customfield_DolzhnimiUSD=0&customfield_ObovyazkiUSD=0&customfield_DolzhnimiEUR=0&customfield_ObovyazkiEUR=0 1s the programmer having said that in the new one he manages one request at a time. Possibly, there was a problem with the test base - call tezh to correct the request. Can you clean up the records de double?
