Action changed owner when process was no longer present [file]11929[/file]
https://rivcont.info/app/history/orders/2532921/?systemchange=1&filter2_key=valueold&filter2_type=search&filter2_value=&filter3_key=valuenew&filter3_type=search&filter3_value=&fieldkey=&filtercdatefrom=&filtercdateto=
09:07:32 action changes the responsible person to Nastya
12:23:25 the responsible person changes the stage of the process (after this action should not change the responsible ones)
12:23:25 action changes the person in charge to Yura
I suppose the list of processes where the responsible one should change was formed earlier, and after working out the crone changed the responsible one according to this list?
Can we fix this?
Or before changing the responsible person, checked the stages of the processes
Or an action on the stage that will forcibly remove the process from this list
Action changed owner when process was no longer present https://rivcont.info/app/history/orders/2532921/?systemchange=1&filter2_key=... 09:07:32 action changes the responsible person to Nastya 12:23:25 the responsible person changes the stage of the process (after this action should not change the responsible ones) 12:23:25 action changes the person in charge to Yura I suppose the list of processes where the responsible one should change was formed earlier, and after working out the crone changed the responsible one according to this list? Can we fix this? Or before changing the responsible person, checked the stages of the processes Or an action on the stage that will forcibly remove the process from this list
Vysokos Nikolai Aleksandrovich wrote: no, every few weeks
In this case, I will not offer you an adequate solution that will not cause additional problems. this is a normal overlay of parallel processes
no, every few weeks
We understand, but I would like to resolve the issue at the root. The problem may appear more often when more employees are enabled in the action "Automatically distribute employees' business processes to other employees" Whether it is possible to stop forcibly change on one process? For example, an action on the stage ?
OneBox production
no, every few weeks
Vysokos Nikolai Aleksandrovich wrote: Whether it is possible to stop forcibly change on one process? For example, an action on the stage ?
you can modify the check to check if there has been a change in the responsible person, for example, in the last N seconds (make the setting - 1h) would this solution work?
