https://rozpakui.crm-onebox.com/admin/auto/action/minute/edit/
We previously made improvements so that the first 2 actions work on a separate minute crown (or somehow run in parallel):
- Import processes from opencart
- Turn a letter into a process
Checked now, emailed 13:57, logged in at 14:06
Please check:
1. Does what they did now work so that it works in parallel or on a separate crown, something may have broken
2. Is it possible to speed up somehow so that these 2 actions really work once a minute?
https://rozpakui.crm-onebox.com/admin/auto/action/minute/edit/ We previously made improvements so that the first 2 actions work on a separate minute crown (or somehow run in parallel): - Import processes from opencart - Turn a letter into a process Checked now, emailed 13:57, logged in at 14:06 Please check: 1. Does what they did now work so that it works in parallel or on a separate crown, something may have broken 2. Is it possible to speed up somehow so that these 2 actions really work once a minute?
The action "Turn a letter into a process" does not turn a letter from the mailbox into a process, but an event. The event is created by a separate cron. If a letter is parsed from gmail mail, then cron parses gmail mail once every 15 minutes. If you do it more often - Google bans the ip of the server.
not so long ago, google made application passwords, they do not need any additional access, etc. they always work fine, but in order to create such a password, there must be two-step authentication, and very soon it will be mandatory for all Google boxes. So, I'm leading to the fact that you can connect with this password more often?
there is an option to turn off parsing every 15 minutes and make requests once a minute, but Google can ban for this i.e. purely at your own risk. We will not cut new authorizations in mvp
anonymous duck OneBox production Employee wrote: there is an option to turn off parsing every 15 minutes and make requests once a minute, but Google can ban for this i.e. purely at your own risk. We will not cut new authorizations in mvp
Authorization does not change, only a special password needs to be generated there, you can try to file a setting for gmail. I can help set up a password if necessary, but I won’t tell you about the connection every minute, this is just a test
anonymous duck
OneBox production
anonymous duck OneBox production wrote: there is an option to turn off parsing every 15 minutes and make requests once a minute, but Google can ban for this i.e. purely at your own risk. We will not cut new authorizations in mvp
Can we temporarily turn on for the test so that it parses once a minute? To check if banned or not
anonymous duck
