It is impossible to go to the LK setup from the side of the System upgrade.
https://astelitgroup.crm-onebox.com/admin/shop/settings/
To be brought manually enter the address of the side of the personal account setup
[file]10562[/file]
The food is in the way that you can get to the side through navigation
https://astelitgroup.crm-onebox.com/admin/shop/boxclient/
from the side
Kotsiubinsky Roman Alexandrovich
from the side
No, only from OneBox Market or add to the menu
Power in that, in the initial video of the readings, the transition to the setting of the personal account: through the sequence Global menu => System settings => Other, in the Search, write "Page of the personal account". In my version, it is impossible to go to the personal account setup through Search. https://youtu.be/VXW6KgK83Xo?t=83
Kotsiubinsky Roman Alexandrovich Astelit Group wrote: Power in that, in the initial video of the readings, the transition to the setting of the personal account: through the sequence Global menu => System settings => Other, in the Search, write "Page of the personal account". In my version, it is impossible to go to the personal account setup through Search. https://youtu.be/VXW6KgK83Xo?t=83
The video is already old, it was recorded on the other version of the system - revolution, after the release of the MVP version, it was upgraded to OneBox Market, and in the OS version it was upgraded as an extra addition. From time to time everything changes
