On the example of such an Order - https://rozpakui.crm-onebox.com/admin/customorder/order/1685352/edit/ it is clear that in the field with the drop-down list type [file]10407[/file] I can copy-paste the value.
This poses a problem for users as the field is only meant to select a specific value in it.
Why does the field work like this?
How can I make it so that only the selection from the drop-down list is available in it?
On the example of such an Order - https://rozpakui.crm-onebox.com/admin/customorder/order/1685352/edit/ it is clear that in the field with the drop-down list type I can copy-paste the value. This poses a problem for users as the field is only meant to select a specific value in it. Why does the field work like this? How can I make it so that only the selection from the drop-down list is available in it?
Because we thought it would be better that way. If an employee needs to choose from a drop-down list, let him open the edit field and select.
I don't think we will do this - because it deprives several possibilities: 1. inserting a value without opening the selector (such a value as it is in the selector) 2. inserting a variant of the value, which may not be among the options - but needs to be inserted (for example, when they started writing the value, but there is no way to add it to the drop-down list of rights - and who can add it is busy).
Set as on/off setting is there an option for this?
OneBox production
