Does not store a variable that starts with a letter in a sub-field of type "String" and "Text"
Good afternoon, when saving a value that starts with a letter in the additional field "Product ID Socket Pa ***", the system simply resets the cell, we tried it on the string and text types. If you save numbers, or numbers with letters after the numbers - everything is ok. Look please.
Specify on which product you can check for an error? And what is the correct value?
16.08.2021, 16:49
Commentary is available in ru and not yet translated to the current language.
17.08.2021, 15:58
https://gmstore.crm-onebox.com/admin/products/action/update/edit/
you have automation for products by automatically calculating this field using the formula 10000000+[id]
only here is the formula calculated as 10000000 + 02442 (because the variable, as written, returns a 5-bit number) will be equal to 10001314 (because 02442 translates from octal to decimal)
you need to use a formula like 10000000+ltrim("[id]", "0") - then you get the correct 10002442
18.08.2021, 15:46
