Good afternoon
it would be great if it was possible to move the procedure buttons to a new panel that could be collapsed separately from the main status panel. because now they are heavily mixed and take up a lot of space.
It was: http://joxi.ru/vAWdOgEHqN44Rr
Now: http://joxi.ru/VrwRz1GC8LqQMA
Please note that the statuses of the business process itself remain visible at the bottom, and all procedures should be hidden in the sidebar
at the same time, it should be possible to sort the sequence of buttons on this panel using a serial number.
what do you think?
Good afternoon it would be great if it was possible to move the procedure buttons to a new panel that could be collapsed separately from the main status panel. because now they are heavily mixed and take up a lot of space. It was: http://joxi.ru/vAWdOgEHqN44Rr Now: http://joxi.ru/VrwRz1GC8LqQMA Please note that the statuses of the business process itself remain visible at the bottom, and all procedures should be hidden in the sidebar at the same time, it should be possible to sort the sequence of buttons on this panel using a serial number. what do you think?
