Do not go under role access to create a new contact
Here https://icoloronebox.crm-onebox.com/app/contact/?aclgroupid=3&setAclMode=1
such settings for the access rights of the spіvrobіtnik
- at the dealer All contacts: screen 1155
- at retailers Access by group: screen 1156
If so, the spivrobitnik cannot make a new contact.
I see a pardon: screen 1157 and 1158
If you change the All contacts setting like this: screen 1159
then the helper can already create new contacts
ALE at tsimu vin start bachiti all contacts in a row
but not less than that, which lie down to the group, for which you are allowed to practice
I ask you to correct it, or explain it, how you can fix it with a higher rank.
Dyakuyu
I'm testing under the accesses of this spivrobitnik:
https://icoloronebox.crm-onebox.com/app/employer/46/permissions/
Original question is available on version: ru Вячеслав Легеза
You create a contact, it is most likely that you initially have it without a group. The user does not have access to view a contact without a group, he gets an error when trying to go to the contact card. If so, then there are 2 solutions:
1. In the access rights settings, set the right to view the contact "Without group"
2. Create a contact immediately with the desired group
27.05.2022, 14:30
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
anonymous hamster
the other option is not to go right away, because it’s very close to being able to
reversing the first
by ticking the axis rights settings like this: screen 1168
all one sees the same pardon: screen 1169
30.05.2022, 10:19
Вячеслав Легеза Original comment available on version: ru
ФОП Легеза В.В.
Garna is a novelty, who knows the rozvyazannya.
It’s not a garna novelty, what to do with the teak method;)
Tobto there is nothing obvious to the algorithm, which would help to increase the vidpovidnі nalashtuvannya vіdrazu without dancing with a tambourine.
Then you need to put one more tick: screen 1170
Spivrobitnik for the creation of contacts requires the mother of the minimum access y Access by spivrobitnik
30.05.2022, 11:07
