How to add multiple values ​​to a feature filter
I found in the interface designer (when creating a product) that you can add a separate block with socket characteristics guides. (Screen 1).
Is it possible to select 2 values ​​in 1 filter? (Screen 2)
Yes, in the interface designer you can really add separate blocks with feature guides, as in Screen 1 — this is very convenient for structuring data. As for filters (Screen 2), currently the ability to select two or more values ​​within one filter depends on the type of filter used. If the filter is configured as a multi-selection (checkbox or multi-select), then you can select multiple values. If the filter works as a radio-button or dropdown with a single selection — unfortunately, no. We recommend checking the filter type in the settings or contacting technical support to change the configuration.
17.06.2025, 09:09
