After adding automation (when editing the directory), how to run it for the entire directory so that the fields on all lines are updated?
That is, there is a directory, one more column was added to it and a formula was written
Now it is necessary for the system to write down this formula on all the lines of this directory
Tried to do export/import, as well as selection of all entries of the directory and through the panel of mass work and change, nothing helped, I write down the formula (it works) only if you edit one entry at a time.
you can pull the update of the reference manual for api v2, the automation of the reference manual is called there. You can also improve the ability to mass call automation through the admin panel, it will take about 2 hours of improvements. Bill?
14.04.2023, 23:18
Юля
менеджер
No thanks, the task is not critical enough to make improvements to it
15.04.2023, 12:00
