Do not show possible options if a certain field is not filled or the data does not match
https://univer.1b.app/desktop/
It is necessary not to show options from the directory if there is no match in other fields.
Under this client https://univer.1b.app/app/contact/44/
in this process https://univer.1b.app/client/order/24125/
https://take.ms/YSKs5
There should not be such a large list, since there are only 2 items in the customer guide https://univer.1b.app/app/customobject-6/?kliient=44&kliient=44&ok=Filte...
Is this a bug or how many hours does it take to fix?
try to shove them into one block, if it doesn’t work, write
13.01.2023, 14:22
bu
Already tried. I just tried it again and left it like that, it still doesn't work https://take.ms/b7Nen Apparently some fields that are not displayed may conflict.
13.01.2023, 14:46
understood. Give me a link to set up this page, I'll take care of it
13.01.2023, 14:47
13.01.2023, 14:53
You need to rewrite the filtering so that it can take into account fields with the "Multilist of contacts" type. Now, due to the fact that it filters like regular strings, it finds the wrong values. Rewriting will take 1 hour. improvements
17.01.2023, 17:47
bu
Another clarification. If there are no records on the contact at all, can nothing be displayed?
18.01.2023, 13:06
Yes, this is how an empty list will work.
18.01.2023, 13:07
Please send an invoice to Pyatetsky Nikolai Nikolaevich
23.01.2023, 14:14
Julia seems to have already billed here, ask her to re-issue if necessary for another person.
23.01.2023, 14:47
