"Edit Directory Entry Based on Process Fields" based on process product subfields.
We update the entries in the directory based on the subfields of the process products with the action "Edit an entry in the directory based on the process fields" (BP step https://ceylon.crm-onebox.com/admin/shop/workflowstatus/176/action/new/ ). We noticed the following feature: If there are several products in the process based on subfields for which entries in the directory need to be updated ( example https://ceylon.crm-onebox.com/admin/customorder/order/102/edit/ ), then the system updates the values only according to the first product (others remain unchanged) (reference with brands from this process https://ceylon.crm-onebox.com/admin/shop/custom/object/directory/3/?vikoristana=... A4%D1%96%D0%BB%D1%8C%D1%82%D1%80%D1%83%D0%B2%D0%B0%D1%82%D0%B8 )
Please tell me, is it possible to update the directory entries based on all the filled subfields of the process products?
Vasylyk Taras
2 hours finishing
21.12.2022, 18:39
