process https://crm.ohrana.ua/admin/customorder/order/2679103/edit/, the item is listed as reserved http://joxi.ru/Dr8YD3EsJxBG7m, but if you go to the item in reserve at this warehouse https://crm .ohrana.ua/admin/shop/storage/reserve/?balanceid=161865 - then there are 2 positions in reserve, but the above order id 2679103 is not [file]12445[/file]
Please help to solve the problems with the rest of the warehouse, the negative balance of the warehouse regularly climbs out, now the reserves are not relevant either
Good afternoon. process https://crm.ohrana.ua/admin/customorder/order/2679103/edit/, the item is listed as reserved http://joxi.ru/Dr8YD3EsJxBG7m, but if you go to the item in reserve at this warehouse https://crm .ohrana.ua/admin/shop/storage/reserve/?balanceid=161865 - then there are 2 positions in reserve, but the above order id 2679103 is not Please help to solve the problems with the rest of the warehouse, the negative balance of the warehouse regularly climbs out, now the reserves are not relevant either
