Very urgent! Error 500 - problem with document template
In processes when generating a document with the template Order to the supplier using the action "Issue a document" https://one-box.shine-bright.com.ua/app/document/templates/19/control/ Error 500 occurs
no changes were made
example of the process https://one-box.shine-bright.com.ua/714606/ - you can go to the Update stage
the document is also not generated manually in orders
Correct errors in the template
{|if (product_count) > 1|}
02.09.2025, 13:25
so no changes have been made to the template since 23, and orders were still being generated yesterday
02.09.2025, 13:40
ok, you don't have to correct it)
02.09.2025, 13:52
He drinks fuel like it's free
Well, can you explain what's going on? Why did it just stop working from today? Did some changes happen in your system? We didn't change anything in the settings - is that a fact, or am I wrong?
02.09.2025, 13:59
Rodion wrote:
Well, can you explain what the matter is?
I explained it to you in the very first message - you have an error in the document template. {|if (product_count) > 1|} is an invalid construction.
Validation has become more rigorous.
02.09.2025, 14:01
Please tell me how to correctly write such a condition?
02.09.2025, 14:06
Remove it altogether
<td class="xl9912913" style="border-left: none;" colspan="2">{row:product_count}</td>
{|else|}
{|/if|}
1. This is an invalid construction.
2. It is meaningless
i.e. just leave one td
02.09.2025, 14:09
thanks, is there a design to highlight a cell in color if the quantity of goods is > 1?
02.09.2025, 14:28
I can't tell you - you need to test it, create a separate thread with a similar question - if anyone knows, they'll tell you.
02.09.2025, 14:38
