A problem with displaying services in the document
In the document template, I set up a separate display of goods and services. There were no problems with the goods. And the services are not displayed. According to the documentation, I use the view from {row:service_*}
The following variables are required
{row:services_name}
{row:service_unit}
{row:service_productpriceoutdiscount}
But the data is not displayed in the document. Please tell me how to display the variables correctly
Olga, good afternoon,
it seems you went a bit more complicated - the {row:product_name} variable works for all types of products.
Do you need to somehow separate services and goods in documents?
27.03.2023, 11:12
Ihor Susiak
Congratulations! Yes, I need to display two tables with products in the document, one with services, the other with goods
27.03.2023, 11:16
Good afternoon
Corrected your document template, now 2 different tables are displayed in the document
Your variables were specified a little incorrectly, I did it so that it would work: there is no variable {row: service_*}, instead of * you need to substitute the key by analogy with variables for displaying goods, also instead of {row: services_name} you need to specify {row :service_name} and no tags or spaces in the name of the variable itself
27.03.2023, 14:07
Thanks for the promptness ????
27.03.2023, 14:13
