Establishing a link between a product and a customer order and an order to a supplier.
I will describe the situation that arose in connection with the supplier's order:
There are 2 customer orders
https://crm.dobavki.ua/admin/customorder/order/243400/edit/
https://crm.dobavki.ua/admin/customorder/order/243397/edit/
An order was created to the supplier for these 2 customer orders https://crm.dobavki.ua/admin/customorder/postachannya/243398/edit/
Since these are the same products, they were combined with the action Combine process products with the same product codes
And the connection remained only with 1 customer order
Can it be done in such a way that, when combining goods, links with customer orders are not lost, but remain?
That is, if there are 3 products with the same ID and they have their own links with customer orders, then after the merger, there are 3 links left for one product?
Hello, as far as I remember, one supplier product cannot be tied to 2 different process products. It is only possible to bind 2 different products of the supplier to one product of the customer's process. If you use these links only in a few actions, we can modify them so that they use other links/fields to understand which order the product was ordered for. What do you want to do with related products later?
05.05.2021, 13:57
Little Vanderquack
This is necessary in order to capitalize the goods in the order to the supplier and in the customer's order by relations, these goods have become a reserve
05.05.2021, 16:47
Strilec Anton Nikolaevich
KTS Premium Partner wrote:
Little Vanderquack
Can this be implemented?
06.05.2021, 21:07
Yes. If only for this field, then you can write the id of related products in the additional field when merging and in the action of posting, look in the additional field and reserve the necessary products. Takes 5 hours
10.05.2021, 17:28
T-34
OK understood.
Is it possible to do this in the system field Setting up suppliers? So that there were several links and, accordingly, links to customer orders?
11.05.2021, 09:27
In theory, yes, in practice, this connection is used in ~ 50 places in boxing, and I doubt whether they should be refactored for this.
11.05.2021, 09:29
