Good afternoon!
Problem with unloading the built-in report called "Sales Report".
When setting up the report, I select the necessary data about the client of the process by ticking the boxes. They are displayed in a table on the screen as a block of columns, but when the xlsx file is uploaded, they are not there.
Link to customized report:
https://zavod.crm-onebox.com/admin/shop/report/sales/?filtermanagerid=&filtercategoryid=0&datefrom=2021-02-24&dateto=2021-03-10&dateclosedfrom=&dateclosedto=&datestoragefrom=&datestorageto=&workflowid%5B%5D =22&statusid%5B%5D=569&statusid%5B%5D=768&statusid%5B%5D=267&statusid%5B%5D=454&statusid%5B%5D=686&statusid%5B%5D=767&statusid%5B%5D=833&statusid%5B%5D=834&statusid %5B%5D=835&statusid%5B%5D=836&statusid%5B%5D=837&statusid%5B%5D=838&statusid%5B%5D=839&statusid%5B%5D=840&statusid%5B%5D=1100&statusid%5B%5D=1170&statusid%5B %. =1392&statu
Good afternoon! Problem with unloading the built-in report called "Sales Report". When setting up the report, I select the necessary data about the client of the process by ticking the boxes. They are displayed in a table on the screen as a block of columns, but when the xlsx file is uploaded, they are not there. Link to customized report: https://zavod.crm-onebox.com/admin/shop/report/sales/?filtermanagerid=&filte... =22&statusid%5B%5D=569&statusid%5B%5D=768&statusid%5B%5D=267&statusid%5B%5D=454&statusid%5B%5D=686&statusid%5B%5D=767&statusid%5B%5D=833&statusid%5B%5D=834&statusid %5B%5D=835&statusid%5B%5D=836&statusid%5B%5D=837&statusid%5B%5D=838&statusid%5B%5D=839&statusid%5B%5D=840&statusid%5B%5D=1100&statusid%5B%5D=1170&statusid%5B %. =1392&statu
Good afternoon. The contact fields from the filtering on the left do not get into the xls export. But we can finalize it for you if you switch to a cloud plan or in 2 hours of revision.
You didn't quite understand me. I don't need the _filtering_ fields to be included in the report. I need the fields that I ticked as _displayable_ to be included in the report. Once again: yes, in the panel on the left there are filtering fields and fields that, if checked, will appear as a column in the report. I speak of the latter, and you, Gimli son of Glóin, speak of the former. Client fields are displayed on the screen, but they are not uploaded to Excel. I think that's how it should be. Everything that is output in the request should be output to a file.
Good afternoon. I understood what you want to do and estimated how much it can be done. What you described will take 2 hours ps I was disappointed in the gnomes (
I have a historical fact that OneBox recognizes such situations as a bug and fixes them for free 3 hours after the request. Eremenko Artem Alexandrovich will confirm this. I think this is a bug and I ask you to fix it for free.
[file]4306[/file]
[file]4307[/file]
[file]4308[/file]
Link to the task in my box:
https://zavod.crm-onebox.com/admin/customorder/support/202497/edit/
Identical history - the request data was displayed, but it is not unloaded in Excel. The question is - why then they were displayed?
